2 members (Peggy M, cmayna),
226
Mod | | | Forums66 Topics128,282 Posts1,058,495 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2003 Posts: 58 | Hi Guys , I'm back to the fountain af knowledge for another drink. My question is are there any different driveshaft yokes that will fit with my new t-5 from an s-10 pickup. I got the trans bolted up to the back of the 235 in my 1961 p/u. I went to the junk yard the other day to find a driveshaft yoke off an s-10 and couldn't find anything with a t-5 that had not allready been stripped. so are there any other transmissions that have the same output shaft as mine so I can pull the yoke from another type of car.And this this brings up Question nomber two. Are all these yokes the same on the driveshaft side? In other words will I be able to just knock my old yoke off and install the new one in its place | | | | | Joined: May 2004 Posts: 62 Member | | Member Joined: May 2004 Posts: 62 | Tony,
Best bet is your local driveline shop. They should have the T5 yoke in stock and they aren't that expensive.
The only difference in yokes I am aware of is either internal or external snap ring location.
47 Fleetmaster, Hotrod 6, 5 Speed 50 Sedan Delivery, 327, 5 Speed
