6 members (GMCJammer51, Greg_H, NorCal52Suburban, Hush, Cosmo, 1 invisible), 70 guests, and 2 robots.
Topics128,073
Posts1,055,908
Members48,429
#20570 02/25/2004 5:36 PM
So I found a 70/71 GMC 350 complete..
Will this fit into my 68 c-20?
What problem might I run into? additional parts needed?
Will the old tranny bolt up?
Anyone need the 292 that is coming out?
thanks
#20571 02/25/2004 6:09 PM
If you weren't so far away I'd take the 292. They go for $400 around here, the farmers use them for irrigation pumps.
As for your engine, it's not a drop-in, but not that tough. Bell housing is the same. You will need motor mounts. Carb linkage is different, depending on the year. In 71 GMC switched to a cable instead of the rod. Switching the isn't that hard, you can either buy used or a new Lokar pedal and cable.
Fred
52 3600
69 C-10
#20572 02/26/2004 7:57 AM
The 292's right-side motor mount is offset, you'll have to move it back for the V8. The holes should already be in the frame.
1954 GMC De Luxe COE
#20573 02/27/2004 8:02 AM
The guy I am buying the motor from is offerring me a "package deal", the motor[350] ,tranny [auto] and radiator for one price.
Is the tranny worth using?
I dont mind the stock tranny in the truck now, if i do this do I need to change the drive line and rear end also?
Pros vs cons?
thanks-
#20574 03/05/2004 8:37 PM
Stick with what you've got!Simpler, and you know what you've behind the engine right now.
65 C10 292/700R4 long fleet...Gettin closer by the day.
#20575 03/05/2004 8:47 PM
Anonymous
Unregistered
Anonymous
Unregistered
did someone say - free 292 in the portland area? :p
