| | | Forums66 Topics128,060 Posts1,055,839 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#20570 02/25/2004 5:36 PM | Joined: Oct 2003 Posts: 15 Member | | Member Joined: Oct 2003 Posts: 15 | So I found a 70/71 GMC 350 complete.. Will this fit into my 68 c-20? What problem might I run into? additional parts needed? Will the old tranny bolt up? Anyone need the 292 that is coming out? thanks | | |
#20571 02/25/2004 6:09 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | If you weren't so far away I'd take the 292. They go for $400 around here, the farmers use them for irrigation pumps.
As for your engine, it's not a drop-in, but not that tough. Bell housing is the same. You will need motor mounts. Carb linkage is different, depending on the year. In 71 GMC switched to a cable instead of the rod. Switching the isn't that hard, you can either buy used or a new Lokar pedal and cable.
Fred 52 3600 69 C-10
#20572 02/26/2004 7:57 AM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | The 292's right-side motor mount is offset, you'll have to move it back for the V8. The holes should already be in the frame. | | |
#20573 02/27/2004 8:02 AM | Joined: Oct 2003 Posts: 15 Member | | Member Joined: Oct 2003 Posts: 15 | The guy I am buying the motor from is offerring me a "package deal", the motor[350] ,tranny [auto] and radiator for one price. Is the tranny worth using? I dont mind the stock tranny in the truck now, if i do this do I need to change the drive line and rear end also? Pros vs cons? thanks- | | |
#20574 03/05/2004 8:37 PM | Joined: May 2003 Posts: 57 Member | | Member Joined: May 2003 Posts: 57 | Stick with what you've got!Simpler, and you know what you've behind the engine right now.
65 C10 292/700R4 long fleet...Gettin closer by the day.
#20575 03/05/2004 8:47 PM | | Anonymous Unregistered | | Anonymous Unregistered | did someone say - free 292 in the portland area? :p | | |
