| | | Forums66 Topics128,012 Posts1,055,316 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 284 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 284 | Will a pick up box from a late 40's early 50's truck fit on a 42 1/2 pick up? Does any one know the difference between the two? Thanks | | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | The Short Answer is yes.
The Long answer is:
The box off of an AD is a little bit wider than the ones off of the Art Decos, and the mounting is a little different, but you can do it without too much difficulty. You may have to custom cut some mounting blocks to make it fit.
Make sure that you get the short box, though. The long one (3/4 ton) won't work so hot unless you have a long wheelbase 1/2 ton. | | | | | Joined: Mar 2005 Posts: 284 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 284 | Thanks for the info. By the way what state looks like a mitten? | | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Originally posted by dad6timz: Thanks for the info. By the way what state looks like a mitten? Why, Michigan, of Course. And you're welcome! | | |
