1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#20536 03/16/2002 2:28 AM | | Anonymous Unregistered | | Anonymous Unregistered | I have a 1954 235 ci. motor, bored over .060 head is milled .035 it has Alu pistons stock valve train solid lifters, with a electrinic ignition from a V6 chevy motor. this ignition was built by a shop here in Phoenix. my problum is what heat range spark plug to start with on this motor, this will be a dayly driver in Phoenix Az ( we have very hot summers and very mild winters.) I sure don't want to burn a piston or anything else. I know to run the motor a few miles and check the way the plugs are burning. If you can help E mail me thanks Bobby | | |
#20537 04/22/2002 3:05 AM | Joined: Apr 2002 Posts: 6 Member | | Member Joined: Apr 2002 Posts: 6 | you can get from spark plug manufacturers a color chart showing how to read spark plugs. i would start with the factory specified plug and adjust according to the chart. i would also increase the spark plug gap to use the increased power provided by hei dist. | | |
