1 members (Otto Skorzeny), 85 guests, and 1 robot.
Topics128,162
Posts1,056,941
Members48,458
I've got a 54 3100 and I'm going to need a fender
Is there a difference between them and earlier fenders
I alwas see up to 53 then they start again at 55
I'm a tad confused
thanks
Joe
Joe
Rear fenders are identical. Front fenders for 54/55 are different from 47-53. There is a stamped area up front for the 54/55 parklight housings.
Mike Barnes
1950 GMC 1-ton pickup
Will the 53 or earlier fit and just look different or do they mount up different?
thanks
Joe
Joe
They also mount different where the fenders bolt to the grill. The grill opening on a 54/55 is different than 47/53.
38 original
48 panel
59 stepside
46 in the back forty
Which one are you going to need? I have a drivers side that I can't use.
http://www.bunchobikes.com/subfender.htm
The actual difference in the 54 front fenders is all in the front. The grill opening is the same in opening shape, but the bolt holes in this area are different. The indention for the grill in the front is only 54/55. I think, but not sure, think the splash apron bolt holes are different. Like I said, not for sure on that. If you really need positive info on this, private email me and I'll take a picture of a 53 and a 54 front fender and show you. I have both off and in my shop.
Ron Thompson
51 Chevy 1/2 ton
36 F@rd coupe
65 Riviera
The grill opening at the top should be squarish for the earlier, roundish for the later. That's why I had to take this fender off. It was bending the top of my grill.
I figure the fenders are not as readily available for '54-'55 1st because they were only used for 1 1/2 years...probably why my truck ended up (before my dad bought it in '71) with the earlier fenders and thus, the earlier grille.
Sabrina
Sabrina
'54 3100
I've got a '51 and the Previous Owner had bolted a 54 front clip on. When I got it he said the guy before him did it, and 'thank god they didn't cut the 51 fenders for the signal pods.' Well.... it turns out I've got 54 fenders with the indentation for the turn signals and need the '47-'53 fenders. Sort of planned on swapping them with someone and thought that if I can't find a trade I'll cut out the indentations and weld in some sheet metal to make them into '51 fenders.
Arrrgh! Good 54/55.1 fenders are hard to find - don't cut them! Someone would be happy to take them off of your hands if they are relatively rust free.
1954 GMC De Luxe COE
They've been sandblasted inside and out. There is a little bit of plastic filler (bondo) skim coat on one of them.
They are rust free, straight, and ready for finishing. You'd probably want to etching primer them and/or hit them with a DA and some 80 grit before primering and then painting.
I'd take $350 for both, plus shipping/boxing for them.
What I'd do is take them to a UPS store and have them boxed and shipped.
PS-
I found a set of '51's locally so I won't need the '54 - 55 1st outer fenders and will post them in the swap meet next week.
