2 members (Mike Roache, walter74), 110 guests, and 2 robots.
Topics128,049
Posts1,055,740
#205295 04/02/2006 7:23 PM
ok,so the firing order is 18436572.I know the location of no 1 on the cap.going clockwise is 8 the second wire on or is the no 2 cylender second?In other words do i folow the firing order around the cap after no 1 is on, 8 4 3 6 5 7 2 or do i go by cylender position, 2 3 4 5 6 7 8?
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are...
My progress pics
#205296 04/02/2006 7:57 PM
Ex Hall Monitor
Ex Hall Monitor
I'm sure that if I'm wrong someone will point it out. grin If you know the firing order, the position of #1 on the cap and the direction of rotation of the rotor, the next pin the rotor contacts after #1 would have to be #2 on the firing order. In your case cylinder #8. The next would have to be cylinder #4 etc.. If you connected the second pin to cylinder #2 it wouldn't be on the compression stroke and ready to fire.
#205297 04/02/2006 7:58 PM
THANKS TINY... Back out in the rain to try again.
1942 1\2 Ton
1960 Biscayne Sedan
1965 G/10 panel van
My progress pics
#205298 04/02/2006 8:57 PM
#205299 04/02/2006 9:52 PM
Thanks guys.
1942 1\2 Ton
1960 Biscayne Sedan
1965 G/10 panel van
My progress pics
