| | | Forums66 Topics128,016 Posts1,055,337 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | ok,so the firing order is 18436572.I know the location of no 1 on the cap.going clockwise is 8 the second wire on or is the no 2 cylender second?In other words do i folow the firing order around the cap after no 1 is on, 8 4 3 6 5 7 2 or do i go by cylender position, 2 3 4 5 6 7 8?
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I'm sure that if I'm wrong someone will point it out.  If you know the firing order, the position of #1 on the cap and the direction of rotation of the rotor, the next pin the rotor contacts after #1 would have to be #2 on the firing order. In your case cylinder #8. The next would have to be cylinder #4 etc.. If you connected the second pin to cylinder #2 it wouldn't be on the compression stroke and ready to fire.
| | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | THANKS TINY... Back out in the rain to try again.
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | | | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 |
