1 members (Peggy M), 95 guests, and 1 robot.
Topics128,101
Posts1,056,182
Members48,436
Hi, have a question on the types of oem sway bars used for the advance design years. I have two types, one bolts to the front axle using the original springs u-bolts, replacing the spring bumper with one that is part of the sway bar. The other bolts to the axle just inside the springs using about 5/16 inch u-bolts. One is late and the other is early. Changed around 51. Which one is the late one???
Grant
1950 Chevy 3100
1952 GMC 150 (In Pieces)
1968 Chevy K20
1966 Shovelhead
1978 BMW 100S
Grant,
The second one that you describe sounds like the later model (8 bushings). I could post a phot this evening if you want one.
Tim
Tim, a photo would be nice. I only count 6 bushings on the second one.
Grant
1950 Chevy 3100
1968 Chevy K20
1966 Shovelhead
1978 BMW 100S
Grant,
Here is a pretty bad photo that has a circle around each bushing (two of each of these - two sides - 8 bushings). I might also have a bushing set but I might not be able to look for this until tomorrow.
Tim
Thanks so much for the picures Tim. Looks like the one I have left is the early one.
Grant
1950 Chevy 3100
1968 Chevy K20
1966 Shovelhead
1978 BMW 100S
This site is amazing, I was just out staring at my mewly painted front sway bar and wondering how the bar was placed. I bought it as part of my resto and didn't know if bend went up or down. Come in to the computer and there is a picture. Thanks Tim. How hard is it to get new bushings for this application?
Steve O
1950 Chevrolet 3100 Deluxe Cab
Gallery Page
Webshots photos
Steve O,
MEB349 from Jim Carter , if you have a set like the one in my blurry picture.
Tim
I don't have a sway bar on my '59. Are there good quality kits available?
Also how much of a difference does a sway bar make on a solid axle. I know it makes a huge difference in an IFS. Is it worth the time and money to upgrade?
Adam
Adam
stovebolt2355
http://www.stovebolt2355.com
Adam - don't know about aftermarket ones, but the OEM swaybar for the TF years came on the panels and burbs only, tho it may have been available as an option on the p/u - does make a definite diff w/ the panel bodys different weight distribution, but prolly wouldn't have as much effect on the p/u
