7 members (moparguy, 32Fordpuchoptop, Hanks custodian, ShopRag, Ponchogl, Otto Skorzeny, Phak1),
130
Mod | | | Forums66 Topics128,114 Posts1,056,283 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 125 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 125 | Hi, have a question on the types of oem sway bars used for the advance design years. I have two types, one bolts to the front axle using the original springs u-bolts, replacing the spring bumper with one that is part of the sway bar. The other bolts to the axle just inside the springs using about 5/16 inch u-bolts. One is late and the other is early. Changed around 51. Which one is the late one???
Grant 1950 Chevy 3100 1952 GMC 150 (In Pieces) 1968 Chevy K20 1966 Shovelhead 1978 BMW 100S
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Grant,
The second one that you describe sounds like the later model (8 bushings). I could post a phot this evening if you want one.
Tim | | | | | Joined: Jan 2000 Posts: 125 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 125 | Tim, a photo would be nice. I only count 6 bushings on the second one.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Grant, Here is a pretty bad photo that has a circle around each bushing (two of each of these - two sides - 8 bushings). I might also have a bushing set but I might not be able to look for this until tomorrow. Tim | | | | | Joined: Jan 2000 Posts: 125 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 125 | Thanks so much for the picures Tim. Looks like the one I have left is the early one.
| | | | | Joined: Mar 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 92 | This site is amazing, I was just out staring at my mewly painted front sway bar and wondering how the bar was placed. I bought it as part of my resto and didn't know if bend went up or down. Come in to the computer and there is a picture. Thanks Tim. How hard is it to get new bushings for this application? Steve O | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Steve O, MEB349 from Jim Carter , if you have a set like the one in my blurry picture. Tim | | | | | Joined: Apr 2005 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 50 | I don't have a sway bar on my '59. Are there good quality kits available?
Also how much of a difference does a sway bar make on a solid axle. I know it makes a huge difference in an IFS. Is it worth the time and money to upgrade?
Thanks Adam | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Adam - don't know about aftermarket ones, but the OEM swaybar for the TF years came on the panels and burbs only, tho it may have been available as an option on the p/u - does make a definite diff w/ the panel bodys different weight distribution, but prolly wouldn't have as much effect on the p/u
Bill | | |
