0 members (),
116
0
Mod | | | Forums66 Topics128,127 Posts1,056,679 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | Ive beeen working at geting my 66 ready for the road.Ireplaced plugs,wires,cap n rotor.Idrained and flushed the feul tank and replaced the inline feul filter but not one on carb.P.O. told me carb needed rebuilding as thats what his p.o. told him.Runs fine with choke 1/2 out when warm but backfires and hesitates when opend.Sinse tank was emty i added a bottle of carb cleaner good for 20 gallons to 2 gallons and ran it awhile in a ya never know atempt to solve the problem.What do you recon the problem is.
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | if it sat long enough that you needed to drain and flush the tank, i would put money on your carb needing a rebuild like the previous owner suggested.....
by the way, backfire through the carb is almost always a result of a lean condition.. | | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | Iflushed the tank just so i knew that all the old gas was out and any crap was too.My back firing is out the back.I drove this thing abought 300 mile total over 2 weeks last fall driveing it home and localy.It ran good but needed the choke 1/2 closed.Idont recall if it backfired then but it does now.I also have no power.I couldnt get over 45 driveing tdown my road.I must have screwed something up changeing the cap.My idle is fine with an ocasional backfire out the exhaust but no topend.One wire crossed ?
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | iVE re checked firing order and have it corec t now.Iget up to 55 and it cuts out now.Wont be able to make my trip next weekend to mad town to serve sour krout at the legion so im going to pull the carb and see if i can find someone to rebuild it or find a replacement.
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | Hey Slow..Rider, I had that same problem when I was running a Quadrajet on my 283. Finally bought a a new Edelbrock AFB and that took care of my problem.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | What carb do you have? Some of those are easy to rebuild yourself. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | Just pu7lled the carb.I found a big booger holding the dohickey closed.With the carb upside doun theres a second buterfly type thingy behind the secondary buterfly on the botom.There was a 4 inch piece of silicone strand a bought 1/4inch around wedged in it holding it closed.Idont think the secondarys were opening.Would that cause the choke problem?Pablo, where in cheese land ya from..
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | The carb is a rodchester 4jet.Tag says 702512511 with the 11 being larger.Havent found any other numbers stamped on carb.
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | Howdy Slow..Rider, I'm in Centuria, just north of St. Croix Falls. Moved up here from Texas 7 years ago. How 'bout you?
| | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | Not to far,down in rice lake.
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | | | | Joined: Nov 2002 Posts: 2,767 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,767 | Excellent carb; much better than any of the new ones, plus it is calibrated for your engine.
Disassemble the carb and do a thorough job of cleaning (blow compressed air through all the passages). Put in a good quality rebuilding kit, and you should be good to go. Get rid of all the silicone. Silicone should NEVER be used around gasoline.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | Thanks for the good news Jon.Just ordered a kit will be here tomorow.
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | To Slow..Rider, Yeah, not far away. Do you go to that show they have there in Rice Lake? Also to Carb King: I second the no silicone near gas. My truck quit one day and we found a blob of silicone in the fuel outlet from the tank.
| | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | Theres several held her now.Burger king has 1or 2and theres one thats held at culvers.The guy that hosts it also got to gether with culvers to have a cruise in on thursday nights in the summer.Iusualy go to the big one at cuvlers but lately i park my truck and my daughter shows the cushman.C-MON DOWN. Ron.
