3 members (Otto Skorzeny, Shaffer's1950, Mike B), 62 guests, and 2 robots.
Topics128,123
Posts1,056,653
Members48,450
Ive beeen working at geting my 66 ready for the road.Ireplaced plugs,wires,cap n rotor.Idrained and flushed the feul tank and replaced the inline feul filter but not one on carb.P.O. told me carb needed rebuilding as thats what his p.o. told him.Runs fine with choke 1/2 out when warm but backfires and hesitates when opend.Sinse tank was emty i added a bottle of carb cleaner good for 20 gallons to 2 gallons and ran it awhile in a ya never know atempt to solve the problem.What do you recon the problem is.
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are...
My progress pics
if it sat long enough that you needed to drain and flush the tank, i would put money on your carb needing a rebuild like the previous owner suggested.....
by the way, backfire through the carb is almost always a result of a lean condition..
Iflushed the tank just so i knew that all the old gas was out and any crap was too.My back firing is out the back.I drove this thing abought 300 mile total over 2 weeks last fall driveing it home and localy.It ran good but needed the choke 1/2 closed.Idont recall if it backfired then but it does now.I also have no power.I couldnt get over 45 driveing tdown my road.I must have screwed something up changeing the cap.My idle is fine with an ocasional backfire out the exhaust but no topend.One wire crossed ?
1942 1\2 Ton
1960 Biscayne Sedan
1965 G/10 panel van
My progress pics
iVE re checked firing order and have it corec t now.Iget up to 55 and it cuts out now.Wont be able to make my trip next weekend to mad town to serve sour krout at the legion so im going to pull the carb and see if i can find someone to rebuild it or find a replacement.
1942 1\2 Ton
1960 Biscayne Sedan
1965 G/10 panel van
My progress pics
Hey Slow..Rider,
I had that same problem when I was running a Quadrajet on my 283. Finally bought a a new Edelbrock AFB and that took care of my problem.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
Riding in the Passing Lane
What carb do you have? Some of those are easy to rebuild yourself.
1972 Chevy c10 Cheyenne Super
Just pu7lled the carb.I found a big booger holding the dohickey closed.With the carb upside doun theres a second buterfly type thingy behind the secondary buterfly on the botom.There was a 4 inch piece of silicone strand a bought 1/4inch around wedged in it holding it closed.Idont think the secondarys were opening.Would that cause the choke problem?Pablo, where in cheese land ya from..
1942 1\2 Ton
1960 Biscayne Sedan
1965 G/10 panel van
My progress pics
The carb is a rodchester 4jet.Tag says 702512511 with the 11 being larger.Havent found any other numbers stamped on carb.
1942 1\2 Ton
1960 Biscayne Sedan
1965 G/10 panel van
My progress pics
Howdy Slow..Rider,
I'm in Centuria, just north of St. Croix Falls. Moved up here from Texas 7 years ago. How 'bout you?
Not to far,down in rice lake.
1942 1\2 Ton
1960 Biscayne Sedan
1965 G/10 panel van
My progress pics
Carburetion specialist
Excellent carb; much better than any of the new ones, plus it is calibrated for your engine.
Disassemble the carb and do a thorough job of cleaning (blow compressed air through all the passages). Put in a good quality rebuilding kit, and you should be good to go. Get rid of all the silicone. Silicone should NEVER be used around gasoline.
Jon.
The Carburetor Shop
Thanks for the good news Jon.Just ordered a kit will be here tomorow.
1942 1\2 Ton
1960 Biscayne Sedan
1965 G/10 panel van
My progress pics
To Slow..Rider,
Yeah, not far away. Do you go to that show they have there in Rice Lake? Also to Carb King: I second the no silicone near gas. My truck quit one day and we found a blob of silicone in the fuel outlet from the tank.
Theres several held her now.Burger king has 1or 2and theres one thats held at culvers.The guy that hosts it also got to gether with culvers to have a cruise in on thursday nights in the summer.Iusualy go to the big one at cuvlers but lately i park my truck and my daughter shows the cushman.C-MON DOWN. Ron.
1942 1\2 Ton
1960 Biscayne Sedan
1965 G/10 panel van
My progress pics
