| | | Forums66 Topics128,274 Posts1,058,435 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 328 Member | | Member Joined: Nov 2004 Posts: 328 | I have an old spare radiator from my 94 GMC V6 4.3L Vortec 1/2 ton. We never put it in, so it's still in the box in storage, somewhere. Anyone know if this will work in my 85? In other words, if I check and make sure it's got the 3 rows, should it work in there? If it doesn't fit, maybe I can find a way to make it fit  | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Bought a genaric aluminum radiator from jegs. and was able to modify the brackets to make it fit without much problem. If it is the general same size and the Hose connections are on the right sides. you shouldn't have a huge problem. | | | | | Joined: Nov 2004 Posts: 328 Member | | Member Joined: Nov 2004 Posts: 328 | okay, thanks again Gazim! | | |
