2 members (SNOYL, fonz8261),
343
8
Mod | | | Forums66 Topics128,158 Posts1,057,025 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 9 Junior Member | | Junior Member Joined: Feb 2006 Posts: 9 | I have 1955 2nd series chevy 3600 will 1/2 ton brake drum fit are they inter change able or not. I'm looking to find way to go to 6lug rim instead of 8lug. If that won't work anybody no where to get tires for my 3/4 ton 8lug rims tires say 17.5 inch thanks | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | You would pretty much need to change out both axles to 1/2 ton to get six lugs. Check with a local shop that sells truck tires or do a search online for truck tires, there are lots out there. You might also want to consider switching to 16" 8 lug rims. They are pretty plentiful...atleast at my local u-pull-it. | | | | | Joined: Feb 2006 Posts: 9 Junior Member | | Junior Member Joined: Feb 2006 Posts: 9 | Thanks that a great Ideal that why I asked Thanks | | |
