| | | Forums66 Topics128,274 Posts1,058,436 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 122 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 122 | Looking at stock wheels for my 59 1/2 ton. They are 16" x 6" 6 bolt with three clips if Im correct. Are stock rims from a 1960 1/2 ton 6 bolt the same? Thanks for help. Brian | | | | | Joined: Nov 2004 Posts: 328 Member | | Member Joined: Nov 2004 Posts: 328 | I think Carter Gresham got some a while back for his 55, you might PM him (CGresham or somethin like that).
But I'm pretty sure they were 16 x 6, not 100% sure about 6 bolt | | | | | Joined: Nov 2004 Posts: 328 Member | | Member Joined: Nov 2004 Posts: 328 | sorry it's "cgresham1212" | | | | | Joined: Oct 2003 Posts: 297 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 297 | brian, in looking for brake drums i found that the drums were listed as the same size from 54-59 and from 60-70 provided the 60-70 vehicle had coil springs. all 6 bolt
54 3100 w/62 235 "Yosemite Sam" Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I believe the proper wheels for a '59 have built in nubs for the hubcap and not clips. All my books are boxed up right now because of house painting and I can't check for sure. | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | I have a 59 1/2ton. have one original wheel. 15inch 6 bolt with 3 clips to hold the hubcap.I have 4 hubcaps and one wheel.
Tommy 59 apache 1/2t 261 short stepside | | |
