0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
#20434 04/18/2003 4:56 AM
I've got a '66 K10. I've dropped in a 350 and would like to get some gear ratios to match. The differentials, tranny and transfer case are all stock. I've been told that being its the 4x4 I'm stuck with the stock tranny which would leave my only option being to change the ratios in the differentials which is possible since the K10 uses generic Dyna units. But being the 66 K10 runs a divorced transfer case I'm wondering why I couldn't use a newer 5 speed off a C10?
when the going gets weird, the weird turn pro
#20435 04/18/2003 5:02 AM
If you have a divorced T-Case, you can use any tranny that will bolt up the the bell housing OR even change your bell-housing and the tranny
#20436 04/18/2003 10:35 AM
k10 Offline
Whoever told you that because it's a 4x4, you can't swap tranny's, is flat out wrong. aAs Mech says, you can do it. In fact you have more flexiblity than you would with a modern 4x4. In addition, there are plenty of guys who have gone to a modern tranny/t-case setup.
#20437 04/22/2003 7:30 AM
I didn't think the 'expert' advice would pass the sniff test. I got two pick-n-pulls within 60 miles so I'm going to start doing some shopping. I'll keep the update to a married tranny/xfer case if I can't service the old Rockwell.
