5 members (Gdads51, klhansen, Otto Skorzeny, Steelonsteel, 1 invisible), 76 guests, and 1 robot.
Topics128,051
Posts1,055,710
#204289 03/27/2006 2:43 AM
i started working on my cab today. the guy i bought it from said he had replaced one of the cab corners but his idea of replacing it was to weld a new panel directly on top of it and then slather on the filler. as i started cutting i found a little more rust than i wanted to but it shouldn't be to bad.
http://community.webshots.com/user/brent5631
it's not old it's "aged to perfection"
http://brent5631.myphotoalbum.com/
#204290 03/27/2006 6:59 PM
Looks like your's was worse than mine. PO Rant
Fred
52 3600
69 C-10
#204291 03/28/2006 2:13 AM
that's too bad. same thing with my blue 59,,but i was buying it for parts and cab,, but cab was shot and bondo city, over rust needless to say,,,now i got to cut pieces from one cab to put on the other,should be fun,,i have never replaced the complete windshield surface,might be starting that in a couple of weeks,,,
#204292 04/11/2006 4:46 AM
Thanks for the photos. Looks about like my '59. Mine was cut up worse though, three major patches in the dash alone. Did you look at the cowl air box? I just finished welding on mine tonight. Good Luck. smile
They named it Apache cause it has a patchy welded here and a patchy welded there.
