1 members (SandraD),
56
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 96 | Happy Monday . I just finished rebuilding my front end on my '51 1300. King pins,bushings , brakes etc. I took it off the jack stands and noticed the front wheels are both on an angle ( camber ? )- the tops are out and the bottoms are in . It looks even on both wheels.I don't see any adjustment and wonder if the axel is bent . Is there some way of fixing this ? Any help would be appreciated . | | | | | Joined: Nov 2005 Posts: 355 Member | | Member Joined: Nov 2005 Posts: 355 | Did you put the spindels on upside down? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Here is a picture of the camber angle. The Shop Manual explains how to measure this. I think if you were able to install the spindles upside down, the tops would be in and the bottoms would be out. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | you have something on backwards or swapped from side to side. Make shure the thrust washers are on the bottom of the axle. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2006 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 96 | Thanks for the replys. Does anyone have a photo of their axle I can compare mine to ? My thrust bearings are on the bottom. I centre punched a mark to show which side was which when I began disassembly .My axle does have an upward curve to it ; is this normal ? Pictures on internet manuels show a straight axel but I wonder if this ease of defining the mechanics. thanks Jeff | | | | | Joined: Mar 2005 Posts: 311 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 311 | The front of the truck looks pretty much like the photo tclederman links to in his reply. All of my bent axles had a downward curve (it smiled at me), but a good front end guy was able to fix them without heating. Better yet, can you post a photo of your axle?
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
| | | | | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | Make sure every thing is where it should be, and installed properly.first.
all straight axils i have seen, i remember as straight across. in a fraim shop i worked, we would adjust camber by bending the axil. had a special brace that chained on each end and jack in the middle. no heat. you need to have measuring tools to adjust front geometry. but sight lines work for geting it close. i don,t remember enough bend to be seen.
"It ain't a truck if you can't hose out the cab."
