| | | Forums66 Topics128,080 Posts1,055,950 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 9 Junior Member | | Junior Member Joined: Feb 2006 Posts: 9 | I just bought 1955 chevy 3600 2nd series stepside that was not running install new sending unit clean all gas line and she running now. I need a air cleaner will any 1955 chevy 235 work and how does it attach? Also need hubcaps will 1/2 ton fit my 3/4 ton? How are the reproduction shop manuals? Thanks to all looks like great site | | | | | Joined: Jun 2005 Posts: 209 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 209 | Welcome aboard bigk! We have several threads which will give you the info your looking for. Some just on applications and interchangability. We also have parts wanted and parts for sale sections that will help. Happy hunting. | | | | | Joined: Aug 2005 Posts: 424 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 424 | Welcome thebigk,
Most any air cleaner made for the single barrel carbs will work. Measure the neck on your carb just to make sure. They are pretty easy to come by and not expensive. Mine attaches by clamping on. The clamp is part of the air cleaner. I don't know about your year truck but in the 57-59 years the 3/4 ton does not share the same hubcaps with the 1/2 ton. My guess is that is probably the case the 1955 models too, but I don't know for sure. | | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | Welcome bigK. Do as suggested and post away on the parts board.
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
| | | | | Joined: Sep 2005 Posts: 254 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 254 | I have a 55 2nd series chevy 3600 stepside and on mine the oil bath air filter has a ring clamp type setup on the bottom that you tighten and it just clamps on the carb neck i have a set of hub caps for mine which probly aren't going to be used again because i'm not going to use the split rims again and the truck is kinda in millions of parts so anything ya need let me know (don't know how to do the shipping stuff but i'm in southern minnesota) Nate | | | | | Joined: Oct 2005 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 69 | Hi Bigk Welcome to Stovebolts, the topic search is very helpful
New deal for old steel
| | | | | Joined: Dec 2000 Posts: 163 'Bolter | | 'Bolter Joined: Dec 2000 Posts: 163 | Welcome to the Stovebolt Page! It's good to see another Wisconsin 'Bolter! | | | | | Joined: May 2005 Posts: 323 Shop Shark | | Shop Shark Joined: May 2005 Posts: 323 | thebigk- Welcome to the 'bolt You might want to order up the Restoration Package for your truck, if you don't have one already. BTW, it's free . Sabrina | | | | | Joined: Feb 2006 Posts: 9 Junior Member | | Junior Member Joined: Feb 2006 Posts: 9 | Thank everyone for all the information | | |
