5 members (Ponchogl, ShopRag, 1955 1 Series, Otto Skorzeny, 1 invisible), 120 guests, and 2 robots.
Topics128,268
Posts1,058,375
Members48,485
#20404 03/21/2003 1:14 AM
Junior Member
Junior Member
I need help in removing my transmission so I can replace the clutch on my 1949 chevy 1/2 ton. I own the manual and followed it to the letter. Raised the propeller shaft, removed the U_Joint, did it all. Still I can't get enough room for the clutch gear shaft to clear the clutch disc.Worked on this for two days.Am I missing something?
Please help.
Lonnie
Did you pull the bolt-on crossmember?
Paint & Body Shop moderator
WHat is the tranny hitting when you pull it back?
Junior Member
Junior Member
4onthefloor, thank for your reply, yes I pulled the bolt-on cdossmember.
Mechainiac, I pulled the transmission straight back on the pins and let the ball enage the rear of the transmission as far as it will go inside. Still not enough room for the front spline to clear the clutch housing. Thanks
:confused: Lonnie
C Online: Content
It's been such a long time since I did this but...
Did you remove the cab's floor tranny panel? Maybe that is not necessary though...
Boy, with the propeller raised out of the way, cross member removed, seems like there would be lots of room for an easy removal. Hopefully someone will come in with yet another and better idea..
Craig
Quote
It's been a while since I did anything with a torque tube, but did you disconnect and remove the ball from the driveshaft slip joint? That's the only point of interference my ole brain can picture. I also recall hat to rotate the driveshaft down and out of the way, the rear wheels must be off the ground. Hope this helps...
If the rear axle is on jack stands and the torque tube is disconnected from the back of the tranny, the rear springs will push the tube toward the floor. There should be plenty of room to remove the tranny..
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
Junior Member
Junior Member
Sorry, I didn't remove the crossmember.I removed the rear transmission mount.
Lonnie
#20412 03/21/2003 11:19 PM
I may be wrong on this as it has been a long time but will the torque-tube move down far enough to slide the tranny back frr enough to get it out?
I remember the torque tube missing my head as it slammed into the dirt when I was removing the tranny on a 52 GMC parts truck so be careful when lowering the torque-tube as it colud really hurt eek
Lonnie-49
As has been stated you have to take out the crossmember. Then as mechainiac has stated that tube shaft can be dangerous. When I done mine, I put a floor jack under the shaft and unhooked the u-joints and bell and lowered the shaft to the floor. The transmission should come out now. If you're young and strong you can probably manhandle it. If your getting old like me those days are over and you may have to use a jack. Hey, didn't I get chrome beauty rings from you awhile back? They are still in the same box! :p
1950 3100 5-window
C Online: Content
When I have disconnected my Tube, I first wrap a heavy duty chain around both sides of the chassis crossing under the tube using a double threaded hook system, thus as I tightened the threaded nut, the chain became tight supporting the tube. Then I unbolted the tube. Afterward, I would tighten the threaded hook some more and the tube would raise even further.
Another idea is to first use a jack while unloosening the tube, raise the tube up out of the way, then use a the chain idea which will eliminate having the jack stay in your way during your time under the rig.
Craig
#20415 03/24/2003 12:52 PM
Junior Member
Junior Member
Had the same problem 2 weeks ago.
Lower the torqe tube to the floor (in some cases the car must be touch the ground becaus then thy moove back the whole thing a little bit) then open the lid over the transmission, make sure you disconnected the mounting plate first (gives You mor room to play) withnthe open lid you can slip out the tranny.
hope it helps, Frank
Living in the Past Today
www.TheSavoy.de
Junior Member
Junior Member
Thanks a million!! I should've pull the crossmember first. Removeal would have been easier. So such for the manual!
Lonnie
P. S.
Lionel, yes it's me and I'm still working on my truck. How is it going with your project?
I like to support my transmission through the cab with an engine hoist, it makes it so easy to support. Just pull the floor cover, you can even take it out that way.
