3 members (Cosmo, Wayne67vert, Bills Auto Works), 60 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#204016 03/19/2006 2:27 AM
Not a major problem, but I have newly painted wheels and new repop stainless hubcaps. All wheels have strong clips, so when I try to remove a cap with screwdriver / similar tool results in scratches to rim or cap. Anybody got a clue as to a better "no-harm" removal? BW
#204017 03/19/2006 2:30 AM
:confused: ? Strong suction cup, like for puling dents? smile
#204018 03/19/2006 2:32 AM
Wyant, I remove mine with a plastic knive, push the knive between the cap and rim as if you are trying to cut it... push hard until you can grasp it with your fingers and pop it off.
#204019 03/19/2006 3:07 AM
Wrap the screwdriver tip in duct tape
New deal for old steel
#204020 03/19/2006 12:17 PM
I use those small plastic body putty spreaders between the wheel and the screwdriver to pry off the hub caps.
1936 GMC T-14 1/2-Ton Pickup
#204021 03/19/2006 3:48 PM
I had my rims powder coated in hopes that this issue would not be a problem for me. If I ever get my wheels back on my truck I will try and let you know if this works.
Jim
1954 GMC 1/2-ton Longbed
1971 Pontiac LeMans Sport
#204022 03/19/2006 4:42 PM
I use a "popper offer" that I got from a pal of mine that has a tire center. Basically it is a piece of round stock aluminum 3/4 inch diameter about 18 inches long with a flat edge bent back in a half moon shape similar to a pry bar.
Slide the thin edge under the cap and pry by pushing down on the handle and the cap pops off.
Simple to make and simple to use without doing any damage to the cap or wheel.
Hobert
"The Lord is my shepherd"
