9 members (Sjm, moparguy, SmalltownTRKGuy, Jman, baldeagle, carbking, walter74, Wooley, 1 invisible), 334 guests, and 5 robots.
Topics128,165
Posts1,057,089
Members48,463
Okay, in the process of changing the valve covers, I've run into another problem. On the left side of the engine, the electric choke assembly gets in the way of the valve cover. It's connected to the carb, so I'm not sure if I can remove it. I don't want to screw anything up. Does anyone know if it will hurt? Thanks
edit: Well, maybe it's not the electric choke. It could be, but now I'm doubting myslef. It blots into the maniold/carb on the left side of the engine (if you're looking at it) It has 1 rubber hose that comes out of it, that splits into 2 more.
GO RANGERS grin
Photos Updated so check them out!
its the EGR valve, you must remove it to get the cover off,,brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Thanks Brian, so do I need to put down a catch-pan or anything, or get ready to plug something? I don't want anything to pour everywhere smile And also, do I need to put a new gasket back on it when I put it back on there? Thanks
GO RANGERS grin
no, nothing comes out, 50-50 on whether the gasket will break,brian
Alright, thanks Brian, I'll pick one up just in case.
GO RANGERS grin
