| | | Forums66 Topics128,164 Posts1,056,968 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 328 Member | | Member Joined: Nov 2004 Posts: 328 | Okay, in the process of changing the valve covers, I've run into another problem. On the left side of the engine, the electric choke assembly gets in the way of the valve cover. It's connected to the carb, so I'm not sure if I can remove it. I don't want to screw anything up. Does anyone know if it will hurt? Thanks
edit: Well, maybe it's not the electric choke. It could be, but now I'm doubting myslef. It blots into the maniold/carb on the left side of the engine (if you're looking at it) It has 1 rubber hose that comes out of it, that splits into 2 more. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | its the EGR valve, you must remove it to get the cover off,,brian | | | | | Joined: Nov 2004 Posts: 328 Member | | Member Joined: Nov 2004 Posts: 328 | Thanks Brian, so do I need to put down a catch-pan or anything, or get ready to plug something? I don't want anything to pour everywhere  And also, do I need to put a new gasket back on it when I put it back on there? Thanks | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | no, nothing comes out, 50-50 on whether the gasket will break,brian | | | | | Joined: Nov 2004 Posts: 328 Member | | Member Joined: Nov 2004 Posts: 328 | Alright, thanks Brian, I'll pick one up just in case. | | |
