2 members (78buckshot, IHPWR),
88
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 94 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 94 | I remember some time ago, someone gave a link to someplace that had a template for the somewhere at which to drill mounting holes for the drivers side mirror on an A.D. Whew.. I searched the archives but came up empty. Would someone mind pointing me in the right direction? By looking at the cowl on my truck it looks as though there has been a mirror there before. It has a thin coat of filler, and looking underneath where the mounting holes are supposed to be I can only see one... and it appears to have been filled with lead. I have no idea where the second mounting hole should be, how to gain access to it if it is there, etc. I feel like an idiot, but I'd like to make sure I get this thing in the right spot the first time. I don’t like to drill through vintage metal any more than I absolutely have to. Thanks, -Chris.
1953 Chevrolet 3100
| | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | Open up the door and look from the inside. You'll see the support bracket, etc and where the holes are for the mirror. | | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | And if you ever want to put a mirror on the passenger side, take the same advice and apply to other side. | | |
