| | | Forums66 Topics128,015 Posts1,055,335 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 15 Junior Member | | Junior Member Joined: Mar 2006 Posts: 15 | Is the cab and front end on a 1965 one ton truck the same size as a 1966 1/2 ton pickup | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | I know the frame is wider on the 59 1 ton versus the half ton, but I think all the sheet metal is the same (cab too). | | | | | Joined: Nov 2005 Posts: 266 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 266 | The cab and front sheet metal are all identical on the 10 20 and 30 series trucks from 60-66. The only real difference is how the frame was made since the 1-ton is much beefier than the 1/2-ton. A really good source for the dimensions of your truck is the restoration package that you can order from Chevorlet. That's where I looked this up at.
Drew -------------------- '66 C-10 stepside | | | | | Joined: May 2005 Posts: 119 Shop Shark | | Shop Shark Joined: May 2005 Posts: 119 | I agree with you 66stepside, I had a '65 1-ton for a doner and the cab and front clip were the same as my '66 3/4 ton | | |
