3 members (JW51, moparguy, baldeagle), 83 guests, and 4 robots.
Topics128,014
Posts1,055,327
Members48,419
#203752 03/14/2006 5:51 AM
Junior Member
Junior Member
Is the cab and front end on a 1965 one ton truck the same size as a 1966 1/2 ton pickup
#203753 03/14/2006 9:30 AM
I know the frame is wider on the 59 1 ton versus the half ton, but I think all the sheet metal is the same (cab too).
#203754 03/14/2006 6:41 PM
The cab and front sheet metal are all identical on the 10 20 and 30 series trucks from 60-66. The only real difference is how the frame was made since the 1-ton is much beefier than the 1/2-ton. A really good source for the dimensions of your truck is the restoration package that you can order from Chevorlet. That's where I looked this up at.
Drew
'66 C-10 stepside
#203755 03/15/2006 12:35 AM
I agree with you 66stepside, I had a '65 1-ton for a doner and the cab and front clip were the same as my '66 3/4 ton
