5 members (Wayne67vert, Otto Skorzeny, dt235sd, Cosmo, Hanks custodian), 85 guests, and 2 robots.
Topics128,059
Posts1,055,825
#203741 03/14/2006 12:17 AM
Junior Member
Junior Member
hey, i have a 1959 viking and i removed all 6 wheel cylinders and the master cylinder, honed them out and bought and installed rebuild kits for all of them. I then bled them untill i was positive all of the air was out. when i though i was done i pumped the pedal a few times and the pedal got hard about half way down but once i let off and pushed the pedal about 5 seconds later it went to the floor. i then pumped it another 3 times and held it when it got hard and it did not lose any pressure even after holding the pressure on it for about 5 minutes the pedal still remained hard. If anyone has any idea what might be going on i would sure be greatful to any help or suggestions! thanx!
'53 3100
'59 viking 60
#203742 03/14/2006 12:33 AM
Ex Hall Monitor
Ex Hall Monitor
That one's pretty easy. Fluids are not compressable, gasses are. You still have air in your brakes somewhere. frown
#203743 03/14/2006 12:39 AM
did you adjust the shoes out????how are you bleeding the brakes???
#203744 03/14/2006 1:08 AM
I
I Offline
Isn't a Viking the big bolt model? Does it have a Hydro-Vac? You have to bled it out also, before the wheels and after the master.
Jeff
1947 Chevy 6400 2-ton
1953 3/4-ton
It was fun while it lasted
#203745 03/14/2006 3:09 AM
Junior Member
Junior Member
doc41, thats a good point i did forget to adjust the shoes back out but would the pedal ever get hard with them not out? And ya it is a big bolt with a hydro-vac and i bled it there and im preety sure i have bled the entire system fully. do yall think its possible for the seals in either the wheel or master cylinders to seal under pressure but then loose seal when the pressure is taken of??
'53 3100
'59 viking 60
#203746 03/14/2006 3:27 AM
Usually with air in the system, there is a distinct feeling like you are compressing a spring. Is the rear brake setup like the old twinplex system with one shoe on top and one on the bottom? In that system, the wheel cylinders are vertical and the bleeder is in the middle. I believe that you have to back off the adjusters on the top shoe before bleeding the cylinders.
If you didn't have the shoes adjusted out properly after, then it may be causing your problem.
1951 1 Ton Completed
#203747 03/14/2006 5:54 AM
I
I Offline
Just asking, but did you bled both bleeders on the Vac? Theres one on top and one on the bottom.
Jeff
1953 3/4-ton
#203748 03/14/2006 5:57 AM
Junior Member
Junior Member
no i only bled one of the bleeders but i am preety sure its on top but i will definalty look at that. thanx!!
'53 3100
'59 viking 60
#203749 03/16/2006 4:49 AM
If you replaced/rebuilt the master cylinder, did you bench bleed it before doing the brakes at the wheels?
Dano
my truck gets better every day...every PAYDAY smile
#203750 03/16/2006 4:59 AM
Junior Member
Junior Member
to be quite honest i dont know what you mean by bench blead so...no i didnt
'53 3100
'59 viking 60
#203751 03/16/2006 7:16 PM
I think it's shoe adjustment. The 3 or 4 quick pumps pushes the shoes out and fills the wheel cylinders a little each pump. The one slower pump empties the master cylinder before it can fill the wheel cylinders. My $.02. Good luck.
Professional Novice
