10 members (chevy51truck, Gdads51, Phak1, 52Carl, KEVINSKI, Woodcmiami, Peggy M, Wickedbass, Tinker5, 1 invisible),
40
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,036 Posts1,055,458 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 104 Junior Member | | Junior Member Joined: Mar 2006 Posts: 104 | Onmy 67 C10, I can't get the tailgate to open. It appears that the linkage isn't hooked up. How do I get the doggone thing open?
Then, how do I hook the linkage up so it will work properly.
Davey | | | | | Joined: Sep 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 310 | I did or had to open the tailgate twice. Once,but that was a Nissan with a panel in the tailgate. Took it of and used needlenose to pull the locks. The other time a Dodge, spent quality time with long thin screwdriver to tumble the hooks, but got it open. C10? can you see the hooks from the top ? Else can-opener? Good luck | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | on my f#$d ranger the handle has been frozen for quite some time, dont need to get in it that often, so i just push a screwdriver in to pop the latches. your on your own for the rest 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | I've done Fords too. They have small rods from handle in middle to gate latches. Many times those little plastic clips for holding rods in handle holes are broken or missing. You can remove the handle assembly, and pull on those rods by hand or with tools to open. Not sure if chevy had that or similar? Would think it would have to be. Maybe a cable instead of rod? Remove the center handle first, look around in gate for loose parts if nothing was on handle to disconnect. As said, about any thin tool you can push between gate and box sides and push in the latches should work. Not too handy for all the time, but to start should be ok. You can still get those handles and parts easy for those years. Lots of venders around, check the Links here on this site. Order a manual also, should have your info in there.
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
| | | | | Joined: Sep 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 310 | He Davey, did you get it open? and how did you do it? | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Originally posted by Truck'26: He Davey, did you get it open? and how did you do it? Thanks everybody. I'm finally getting a day off my J.O.B. to work on Venus. The tailgate is "shut tight". I'll look in a couple of the Truck Parts catalogs and see what type of linkage operates it. Hopefully I can remove the bolts from the latch and manually open it. I'll report my experience a bit later. There's go to be a way to get it open. And, if all else fails, I do have a can opener.  | | |
