| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 146 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 146 | im going to pick up a 1.5 ton for parts. theres no grill and a bit of rust in the front cowl and fenders where they come together. what im wondering is how much of a difference there is in the 1/2 ton through to the 1.5 ton. just the fender size or is it the majority of it? im going to get it no matter what,just not sure what i can use on another one. and if anyone needs parts,im sure ill have a few extras. | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | You mean between a 40 1.5 and a 40 1/2 ton?
Cabs would be the same, hood outta be the same, fenders are gunna obviously have a bigger opening to accomidate the bigger front wheels, and probably be wider.
| | | | | Joined: Mar 2006 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 23 | I'm no expert...but I have owned some 49/50/51 pickups and now have a 1945 2 ton flatbed. Is this a dually? What size tires? Mine is a dually w/7.50x20's. If you have 20"tires, the brake drums will be larger w/ larger shoes. The rearend will be heavy duty, not like the pickups.1.5 ton has different axle setup, the way its bolted into the rear housing. My truck has 2-spd. rear w/hand operated shift lever(ARM STRONG) Depending on wheel base, may have a 2piece drive line w/3 U-Joints and middle carrier bearing.I don't remember the PU's having this, maybe longbed 3/4 and 1 ton. I think cab and doors and such are all same, but like you said, fenders are larger. If you have 20" tires there may be some front axle/steering differences maybe in the linkage. Steering box is probably the same. I'm always looking for parts, but I'm in southern oregon.
KEEP ON TRUCKIN,MAMA... TRUCKIN TILL THE BREAK OF DAY... I SAID,KEEP ON TRUCKIN,MAMA... TRUCKIN MY BLUES AWAY...
| | | | | Joined: Nov 2005 Posts: 146 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 146 | im in grants pass. and the truck has the big wheels,but not sure of the size,its too muddy to look at the tire size though. it does have the dual wheels and it has the spacers on them. it has the lights that bolt to the grill area, with the markers on the fenders. its not the 2 speed rear,but it is large and has 2 drivelines. guess that answeres my question... | | | | | Joined: Nov 2005 Posts: 140 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 140 | Do you have a picture of the truck
Now boltless but looking 1951 F-1 350/350 1965 Mustang 355 glide 1971 F-100 401 fe it hates me 1972 Maverick 302 c4
