0 members (),
155
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 101 Member | | Member Joined: Dec 2005 Posts: 101 | I have a nova (disk brakes)front clip on my 55. When I put the brakes on they dont seam to release all the way. If fact you cant even turn the roter by hand. What do you guys think the problem could be.
Roger http://www.flickr.com/photos/45469713@N00/?saved=1
| | | | | Joined: Nov 2005 Posts: 355 Member | | Member Joined: Nov 2005 Posts: 355 | My first quess is that the caliper is corroaded on the outside and dont retract when the pressure is released. My second would be that the slides(where the bolts go though) might be doing the same thing. Take it aparts and see if you got any rust in those areas. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | I agree with Jeff, most likely a rusty caliper but the mounting bolts might make it sieze. It is the piston in the caliper that freezes | | | | | Joined: Aug 2005 Posts: 424 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 424 | I'm no brake expert, but could this have something to do with a residual pressure valve? The valves are sometimes inside the master cylinder and sometimes external. The normal pressure valve is 2 psi for disks and 10 psi for drums. I'm not sure if the wrong one would cause this condition or not. Probably not, now that I think about it. 10 psi doesn't amount to much. Just thinking out loud and trying to consider other causes. The posts above make more sense and would be the first thing I would check. | | | | | Joined: Dec 2005 Posts: 101 Member | | Member Joined: Dec 2005 Posts: 101 | I took that caliper off the truck. I then used my compressor to push the piston out. I used a brake tool to push the piston back. Could it hurt anything to completly push the piston out cause I did. I was able to push it back in the caliper which was not easy. I will take the brakes off over the weekend and try again!
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Years ago on my 75 Camaro, I had the booster and master cylinder replaced by the dealership in town. I picked it up after, drove the 1/2 mile home and you could smell the glue on the front pads. The front discs were not releasing. I took it back and it was an incorrectly adjusted master cylinder linkage that was the problem. The rear drum brakes were not affected by this incident. | | | | | Joined: Dec 2005 Posts: 101 Member | | Member Joined: Dec 2005 Posts: 101 | The truck was sitting for 9 yrs so I am working out all the kinks. This is one of the kinks! I may just purchase some new calipers they are not that expensive. Another kink is that the P/O moved the brake booster under that cab but welded a piece of metal over the only place where you could of added fluid to the reservoir. I have about 3/4 of an inch between the reservoir and the floor board of the truck.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It may be your front brake hoses. They swell up inside & the fluid cannot flow back. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
