Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (Ponchogl), 108 guests, and 2 robots.
Topics128,281
Posts1,058,466
Members48,490
#203320 03/09/2006 11:07 PM
On the door panels of my '54 3600 there are several bolts that have a rectangular head - similar to a flat screwdriver but wider. Are these clutch head screws? If not, does anyone know what they are and how to remove them?
Thanks - Steve
Today is the best day of my life!!!
#203321 03/09/2006 11:16 PM
the original clutch head screws are slightly hour glass shaped sockets - like these - there are screwdrivers made to fit, available at most vendors, and from a lot of tool places, like SnapOn and usually NAPA
#203322 03/10/2006 12:43 AM
Thanks Bill,
Those are the ones... My eyesight ain't what it used to be... They are hourglass shaped. Guess I'm off to NAPA for more stuff - Yeehaa!!
Steve
if you're not into a complete restoration just use 1/4''x20 threaded screws or bolts to replace those old clutch heads
Jim & Caroline
Clifford, go to American Classic Truck Parts.
Under accessories part # MS840 set of 4 Clutch
head drivers 5/32, 3/16, 1/4, & 5/16 for $18.00
Well worth it. Good Luck
Also, Chevs of the 40's Vancouver,Wash., www.chevsofthe40s.com sells screwdriver, 5 bits(1/8"-5/16"),$19.00. All bits fit in compartment in handle of driver...
KEEP ON TRUCKIN,MAMA... TRUCKIN TILL THE BREAK OF DAY... I SAID,KEEP ON TRUCKIN,MAMA... TRUCKIN MY BLUES AWAY...
