1 members (crenwelge),
100
Mod | | | Forums66 Topics128,281 Posts1,058,466 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 90 New Guy | | New Guy Joined: Aug 2006 Posts: 90 | On the door panels of my '54 3600 there are several bolts that have a rectangular head - similar to a flat screwdriver but wider. Are these clutch head screws? If not, does anyone know what they are and how to remove them?
Thanks - Steve
Today is the best day of my life!!!
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the original clutch head screws are slightly hour glass shaped sockets - like these - there are screwdrivers made to fit, available at most vendors, and from a lot of tool places, like SnapOn and usually NAPA Bill | | | | | Joined: Aug 2006 Posts: 90 New Guy | | New Guy Joined: Aug 2006 Posts: 90 | Thanks Bill,
Those are the ones... My eyesight ain't what it used to be... They are hourglass shaped. Guess I'm off to NAPA for more stuff - Yeehaa!!
Steve
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | if you're not into a complete restoration just use 1/4''x20 threaded screws or bolts to replace those old clutch heads
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Jul 2004 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2004 Posts: 85 | Clifford, go to American Classic Truck Parts. Under accessories part # MS840 set of 4 Clutch head drivers 5/32, 3/16, 1/4, & 5/16 for $18.00 Well worth it. Good Luck | | | | | Joined: Mar 2006 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 23 | Also, Chevs of the 40's Vancouver,Wash., www.chevsofthe40s.com sells screwdriver, 5 bits(1/8"-5/16"),$19.00. All bits fit in compartment in handle of driver...
KEEP ON TRUCKIN,MAMA... TRUCKIN TILL THE BREAK OF DAY... I SAID,KEEP ON TRUCKIN,MAMA... TRUCKIN MY BLUES AWAY...
