BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
| | Forums66 Topics126,781 Posts1,039,297 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Mar 2006 Posts: 12 New Guy | New Guy Joined: Mar 2006 Posts: 12 | Can anyone, with some degree of confidence, tell me if the bumper bolts on a 37 Chev half-ton are round head or oval head? If round head, are they high profile or low profile?
Also, has anyone seen the rear fenders attached with clutch head screws? My sources and I are leaning toward the use of clutch head.
Thanks in advance.
Please feel free to email me direct with an answer: cisgww@aol.com | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | welcome to the forum Greg - lotsa pics in the gallery to check, and maybe even some 37 owners you could email to chat with about particulars all the ones visible in the gallery are round head, but I don't know anything about different profiles of bumper bolts - and as far as I've seen, all rear fenders used the clutch heads up to '60 at least you're welcome to send in some pics to the editor and the story on yer truck - we all love pictures Bill | | | | Joined: Mar 2006 Posts: 12 New Guy | New Guy Joined: Mar 2006 Posts: 12 | Sometimes you have the answers right under your nose. On page 109 of the Chevrolet 1937 Engineering Features there is a full front picture of the half-ton pickup clearly showing ROUND head bumper bolts. | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | 'Bolter Joined: Jan 2000 Posts: 2,074 | Greg, Chevy used some really different bumper bolts, my old 36 pickup had a HUGE oval one in dead center of front bumper. Check out this company- www.iandireproduction.com they have tons of repro hardware items for 30s Chevys, also Jim Carters. | | | | Joined: Apr 2004 Posts: 703 Shop Shark | Shop Shark Joined: Apr 2004 Posts: 703 | Greg,
Welcome to the bolt...
As you'll see, with any question you're likely to get several differing opinions. Possibly, cause they're so many differing options.
I've always been under the impression the 36-46 body styles used oval bumper bolts. My experience with the ones I'm familiar with seeing indicate the same.
I just did a quick search of Chev's of the 40's catalog. They're indicating for a 37, an oval headed bolt with either a standard or Marstin nut was used as standard equipment.
What is a Marstin nut? | | | | Joined: Jul 2002 Posts: 166 'Bolter | 'Bolter Joined: Jul 2002 Posts: 166 | My 37 truck came with oval bolts. I believe them to be original as the truck had sat for about 40 years before I bought it. They had about the same amount of rust as everything else on the truck. I think the rear fender bolts are clutch head. I've seen a few 37's at shows and they had clutch head bolts. I'm using the oval bolts for the bumper & clutch head bolts for the rear fenders.
Charles | | | | Joined: Dec 2005 Posts: 324 Member | Member Joined: Dec 2005 Posts: 324 | My 39 with orginal front has oval.
"It ain't a truck if you can't hose out the cab."
