3 members (55shaker, Otto Skorzeny, Charles in CA), 217 guests, and 8 robots.
Topics128,078
Posts1,056,031
Members48,433
#203136 03/07/2006 6:59 AM
Junior Member
Junior Member
Figured it's about time I got the speedo working on My 53 GMC 1/2 ton.
I live in a small town in the boonies so don't have easy access to a speedo repair shop.
I've got the original speedometer. I'm pretty sure it's in working order.
The original cable which is siezed and probably broken in a few spots, and a turbo 400 automatic transmission (bolted to a chevy 400 small block).
Anyone know where I might find the parts to make up a cable that will mate up to the speedo and trany, or someone that could make one up for me.
Any info on this would be most welcome.
Bear :confused:
53 1/2-ton GMC 4x4
54 Chevy 1/2-ton
Ex Hall Monitor
Ex Hall Monitor
I haven't tried for some time but you used to be able to get a universal cable at the local parts stores that you cut to fit for length and then attach the end. It's been years since I bought one and I don't know if such a thing is still available but it's probably worth a phone call to you favorite parts house.
#203138 03/07/2006 11:25 PM
Riding in the Passing Lane
You are probably going to need the cable & caseing assem. The original cable will fit. You can get one at any parts store by measuring the lenght & telling the counter man what kind of ends you have. They are also available at the speciatie stores by application. The metal caseings are easier to work with & look more original but most of them come in plastic.
1972 Chevy c10 Cheyenne Super
Junior Member
Junior Member
Thanks for the ideas. I have checked the local parts stores. Only two of them here and they don't have the parts or know where to get them.
Guess I'll have to go to the big city and shop around.
Thanks again
Bear
53 1/2-ton GMC 4x4
54 Chevy 1/2-ton
#203140 03/09/2006 12:05 AM
Check with American Classic, Chevy Duty or LMC.
