| | | Forums66 Topics128,041 Posts1,055,483 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 112 | who jhere has a 64 -66 with a 3 speed overdrive ? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | fan - I think the 3spd OD was the same from about 55-67 - I've got a couple, but not installed - so what's the question? Bill | | | | | Joined: Feb 2005 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 112 | i need to know was there a switch in the floor like a dimmer switch to engage passing gear and was there a wiring harness for it also was there a relay wired in some hoe any pictures or descriptions will help me tremidously | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the whole 9 yards on the OD is in pdf\'s here and there's some do it yersef wiring info here passing gear [kickdown] switch is on the carb linkage and you can scoop something that'll work off any year junker that has OD - there's a harness specifically for it which is available from some of the vendors Bill | | | | | Joined: Feb 2005 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 112 | | | |
