0 members (), 200 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#203097 03/07/2006 3:59 AM
who jhere has a 64 -66 with a 3 speed overdrive ?
#203098 03/07/2006 4:43 AM
fan - I think the 3spd OD was the same from about 55-67 - I've got a couple, but not installed - so what's the question? grin
#203099 03/08/2006 1:05 AM
i need to know was there a switch in the floor like a dimmer switch to engage passing gear and was there a wiring harness for it also was there a relay wired in some hoe any pictures or descriptions will help me tremidously
#203100 03/08/2006 2:26 AM
the whole 9 yards on the OD is in pdf\'s here
and there's some do it yersef wiring info here
passing gear [kickdown] switch is on the carb linkage and you can scoop something that'll work off any year junker that has OD - there's a harness specifically for it which is available from some of the vendors
#203101 03/08/2006 3:58 AM
thanks red cool links
