| | | Forums66 Topics128,021 Posts1,055,357 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 75 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 75 | I started with a truck with out wheels. I replaced the front drums with a disc set up fromm CPP with 6 lugs. What size after market wheel should I look for so I get the right off set with no interference with the steering arm? Thanks, Bob 1955 2nd series Chevy 3100 | | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | I think that that truck had 16" wheels on a 3100, but I could be wrong.
I'd go with 16x7 rims. Make sure you know your bolt pattern. | | | | | Joined: Nov 2003 Posts: 285 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 285 | Bob--I got 15X6 Rallye 6 Lug Bare (then painted them) 3 3/4" Backspace. When I purchased them in '03 from Wheel Vintiques they cost $55 each. Very happy with them! On the rims I put P205/75R15 tires from Coker Tire. Believe them tires on that '55 2nd Series were 15", not 16". | | | | | Joined: Feb 2005 Posts: 338 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 338 | Bob,
I also have the cpp disc brake setup although my truck is a 1940 it has 1955 1st series axles front and back. The OEM 16 inch rims fit over the caliper just fine. However not everything does. Check your own setup but mine measures over 13 inches at the widest part of the caliper. So the center of any wheel you get has to be like 13 1/2 inches in diameter. I have 16 inch artillery wheel with a 13 1/2 inch center and have to run one of the cpp spacers between the wheel and the rim so the flange on the artillery wheel will clear the caliper.
As far as back spacing goes the original rim is almost centered on the hub. I believe there is about 3/4 of an inch difference between the front spacing and the back spacing. So a 6 inch rim (actually 7 inches wide when you add in the lip) would probably have a 3 1/2 to 4 inch backspace.
The other issue you have to look at is whether the tie rod end is inside the 13 or so inch diameter of the disc break. If your truck is not lowered it probably is inside the diameter of the brakes. If it is inside the tire and rim won't interfere with the steering arm or tie rod. If you are using lowered spindles or a dropped axle, the tie rod end could be outside the rim area and then you need to find out how much distance between the mounting surface and the tie rod. That could limit your rim and tire width or your backspacing. | | | | | Joined: Dec 2005 Posts: 47 Member | | Member Joined: Dec 2005 Posts: 47 | I have used both 16x6 and 15x7 with no problems.
Heres to us and those like us, theres darn few left.
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | This is on my 51 - 3100 std. axle and front end. I have 15x6'' rims'. I use jeep 6 lugs, they do a nice job. You'll be able to fit the disc inside of them. I have Brothers disc (78-84 K5 chevy) on my front end. You can redo the origional hubcaps to fit the new rims. 16's will give you better freeway speed because it's a taller tire. I believe 15's were stock in 55.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
