| | | Forums66 Topics128,022 Posts1,055,381 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | Ihave heard these mentioned here and asked for them at napa.They hadd never heard of them.Tryed 2 more and they scratch there heads and try to sell me a vacume bleeder.Last night i tryed auto zone and the first guy takes me to the vacume pumps.Second guy knew what i wanted and they had them 2 in a pack in the HELP! line.for 10 bucks.Package says for one man bleeder operation install and back off 1/4 turn.MY understanding is these have a check ball in them and dont alow air back in when you realease the pedal.Do they alow only air out ?Ithink my problem is air in the line.P.O.said brakes were fine till he broke a line and after replaceing it its ben a 2 pumper.First pump to floor,second good pedal.Inoticed last night that the new line by one wheel has a lot of bends like the line was way to long and made up for it with s bends.Can i smash the pedal down hard with these valves to get the air out of these bends.
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | | | | Joined: Feb 2005 Posts: 199 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 199 | Hello Slow..Rider. The bends are ok and yes the air will pass by them as if they are not even there.
Bends and kinks are two different things and if you have a line that is bent to the point of restriction you will need to replace the line.
The speedy bleeder does let everything in the line out and does not let anything back in. So if you crack them open you can bleed the line of all air until you get a good clean stream of fluid and then close it without worrying about air sucking back into the line through the bleeder when you release the brake pedal.
Greatest invention since sliced bread!!
Good luck. Hobert
"The Lord is my shepherd"
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You won,t have to "smash the pedal down hard". Loosen the bleeder put a little hose over it & put it in a bottle or can. Then slowly push the pedal down. Make shure the master cyl. does not run out of fluid. There are 2-3 different sizes of bleeders. Make shure you get the right ones. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | I pulled one bleeder off and sent my son to get some .Ive bleed this thing a doezen times and even tryed gravity bleeding with no luck.Im only going to replace the 2 rear bleeders and will post my results later today.Thanks for the advice ,ron.
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Speed bleeders from the "Help" rack at your local A/Z or DiscAdv. are one of the best gizmos ever invented. The key to any bleeding is to "take your time" when pumping out the air. On my 54 with a completely new upgraded system I used 12 slow pumps to clear each of the four wheels. 12 pumps, refill the m/c, do the next wheel, etc. However, if your using a step-bore m/c the procedure is completely different. A s/b m/c can be identified by a larger diameter bore close to the mount and a slightly smaller bore towards the front. If a step-bore is not properly bleed it will be difficult if not impossible to completely bleed the wheel cylinders.
I would suggest you get 4 bleeders and start out just like you had replaced the entire system. 12 pumps on each wheel should remove all the old contaminated fluid and give you the braking power and reliability you need. | | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | They didnt have the corect size in stock for the 66 so ill have to pick them up tomorow.Ill order the front two then.
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | | | | Joined: Dec 2005 Posts: 2 Junior Member | | Junior Member Joined: Dec 2005 Posts: 2 | also if the peddle is hard on the second pump and up to the desired height it may be out of adjustment.Air in the line results in a spongee pedal. Dave | | |
