9 members (tclederman, Otto Skorzeny, 55shaker, Bill Hanlon, Rusty Heaps, 1955 1 Series, BC59, 3800GUY, 1 invisible),
141
0
Mod | | | Forums66 Topics128,104 Posts1,056,201 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 27 Junior Member | | Junior Member Joined: Jan 2004 Posts: 27 | Hello all, Its been a real long time since I've logged in here.
I'm about to be getting back into a project that I bought 2 years ago. Its a '58 Chevy Apache 3600
The question I have is about the wheels.
They are 19.5" 8 lug jobs. They are single piece wheels....pretty skinny with some tall bias plys on them.
At any rate, my question is this: Are these wheels anything special? Like are they factory chevy wheels? I'm going to be replacing the front and rear axles as well as using smaller diameter wheels... Are these 19.5" wheels worth anything if I would try and sell them?
Any info would be appreciated.
TINGLER | | | | | Joined: Nov 2005 Posts: 355 Member | | Member Joined: Nov 2005 Posts: 355 | A lot of mini buses used the 19.5 rims. They should be easy to come by. Most lo-profile chevy big trucks used them also. Not hard to come by, not really worht any great amount of money. I have been told that they dont fit over the brake drums of some older style trucks. We have looked at changing the rim on our 3600's, to 16.5 or 16" ones. You can get them from any 3/4 ton chevy or gmc from 72 to 84. If you use them, you run acrosst clearance problems in the front axil on the tie rods. I'm going to just remove my orginal centers and reinstall them in a one pc 15" rim. I'm using rims from a impala. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | They are pretty rare in single wheels. Frito - lay used a lot of them on step vans back in the early 70,s. Hub caps are hard to come by for them. I think they would have good value if you found someone that wants them. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2001 Posts: 477 Shop Shark | | Shop Shark Joined: May 2001 Posts: 477 | are they single or dual wheels? | | | | | Joined: Jan 2004 Posts: 27 Junior Member | | Junior Member Joined: Jan 2004 Posts: 27 | | | | | | Joined: Jan 2004 Posts: 27 Junior Member | | Junior Member Joined: Jan 2004 Posts: 27 | SINGLE I mean...mispelled it. | | | | | Joined: Jan 2004 Posts: 27 Junior Member | | Junior Member Joined: Jan 2004 Posts: 27 | | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | They'd give you a bit more speed. If you go with smaller wheels you might have to gear up to go on the highway. | | | | | Joined: Jan 2004 Posts: 27 Junior Member | | Junior Member Joined: Jan 2004 Posts: 27 | Not a worry.... I'm changing out the entire rearend to something more modern and a 5 lug pattern.
I'll also be changing out the front axle.
I'm basically converting this truck to a halfton.
.....selling these wheels probably.
I just asked these questions, because I had a fella over here the other day looking at my truck and he went on about how rare those wheels are, and how he'd never even seen a set before.
I never gave them much thought till then. SO I posted this thread on here to see how rare and valuable they are.
Seems like they aren't too awful valuable.
I didn't even know what single or split rim meant...I'm just going by what this guy said. He said they were single piece and he'd never even seen ones that big be single piece? whatever that means.
Like I said, I'm taking them off and losing the 8 lug axles...and even taking out the 235 and replacing it with a v8. | | | | | Joined: Aug 2005 Posts: 8 Junior Member | | Junior Member Joined: Aug 2005 Posts: 8 | I've got some on my 53 3800. I bought them years ago at a salvage yard, they were on an old bread truck. They have the clips and my factory hubcaps fit right on. I found some used Bridgestone radials to fit 8r19.5, I like the tall skinny look. These are expensive tires. Just my 2 cents. Marc in SD, where the snow is still melting.
Marc in South Dakota
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | Seems like I remember a few of the guys on the Napco Owners Group forum looking for these. They wanted them for the 1 ton Napco trucks. If you sell them, be sure to give them a heads up over there. The tires are a little hard to come by, but Pat Wilson(head honcho of the group) found a source for them. | | |
