2 members (gswbbc, Gray_Ghost), 50 guests, and 2 robots.
Topics128,035
Posts1,055,446
Members48,422
#202630 03/02/2006 6:13 AM
Junior Member
Junior Member
information about heaters
I have a 1966 chevy fleetside
and I put in a new heater core
and still can't get any heat
fan works but no heat
#202631 03/02/2006 6:15 AM
Check the heat bypass valve under hood could be stuck closed. Should be in the heater supply line.
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
#202632 03/02/2006 6:16 AM
could be your thermastat not opening
#202633 03/04/2006 6:22 AM
Junior Member
Junior Member
I have replaced the thermastat twice
and there isn't any bypass valve on supply line
when I check the heater core with motor running it gets hot
But no heat gets inside cab
#202634 03/04/2006 7:06 AM
Jim, are there any dampers or doors on the heater that are stuck closed? On my '54 (on which I have bypassed the heater due to a leaking core) the air is either diverted to the defroster or to the cab. Both doors were frozen shut. I you have heat and you have a fan, there can't be many other variables.
#202635 03/04/2006 3:14 PM
Riding in the Passing Lane
With the engine warm & running grab both heater hoses. They both should be so hot you cannot hold onto them very long. If one is cold there is a resriction. If they are both hot you have an air flow problem like tlorber describes.
1972 Chevy c10 Cheyenne Super
#202636 03/08/2006 8:36 AM
Junior Member
Junior Member
Quote
I am having some issues with my heater as well, but doing as posted above should help out. My doors were frozen up pretty good. I put some WD40 on them and the cable to get it free and the doors work fine, also check to ensure the cable isn't bent up like mine was, kinks are a bummer. Good Luck.
"Remember who you are and what you represent"
1961 Chevrolet C-20 Apache
#202637 03/08/2006 1:21 PM
Quote
Wrenchbender wrote: With the engine warm & running grab both heater hoses.
EDIT: Have SOMEONE ELSE grab the hot hoses... grin
66 C10 FS/LB 292/4-spd manual (I also enjoy Hang Gliding)
I'm too sexy for my hair, that's why it isn't there
