1 members (carbking),
103
8
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 15 Junior Member | | Junior Member Joined: Mar 2006 Posts: 15 | information about heaters I have a 1966 chevy fleetside and I put in a new heater core and still can't get any heat fan works but no heat | | | | | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | Check the heat bypass valve under hood could be stuck closed. Should be in the heater supply line.
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
| | | | | Joined: Jan 2006 Posts: 74 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 74 | could be your thermastat not opening | | | | | Joined: Mar 2006 Posts: 15 Junior Member | | Junior Member Joined: Mar 2006 Posts: 15 | I have replaced the thermastat twice and there isn't any bypass valve on supply line when I check the heater core with motor running it gets hot But no heat gets inside cab | | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | Jim, are there any dampers or doors on the heater that are stuck closed? On my '54 (on which I have bypassed the heater due to a leaking core) the air is either diverted to the defroster or to the cab. Both doors were frozen shut. I you have heat and you have a fan, there can't be many other variables. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | With the engine warm & running grab both heater hoses. They both should be so hot you cannot hold onto them very long. If one is cold there is a resriction. If they are both hot you have an air flow problem like tlorber describes. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2005 Posts: 22 Junior Member | | Junior Member Joined: Nov 2005 Posts: 22 | Originally posted by tlorber: Jim, are there any dampers or doors on the heater that are stuck closed? On my '54 (on which I have bypassed the heater due to a leaking core) the air is either diverted to the defroster or to the cab. Both doors were frozen shut. I you have heat and you have a fan, there can't be many other variables. I am having some issues with my heater as well, but doing as posted above should help out. My doors were frozen up pretty good. I put some WD40 on them and the cable to get it free and the doors work fine, also check to ensure the cable isn't bent up like mine was, kinks are a bummer. Good Luck. | | | | | Joined: Apr 2005 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 196 | Wrenchbender wrote: With the engine warm & running grab both heater hoses. EDIT: Have SOMEONE ELSE grab the hot hoses...
66 C10 FS/LB 292/4-spd manual (I also enjoy Hang Gliding) I'm too sexy for my hair, that's why it isn't there
