4 members (Chip O, Otto Skorzeny, Wayne67vert, fonz8261), 51 guests, and 4 robots.
Topics128,077
Posts1,056,016
Members48,433
#202599 03/02/2006 12:40 AM
Howdy,
I was just reading a post in the spotting alert forum. The post shows a '54 with an 83 frame swapped under it. It has me wondering how much work there is to such a swap. It's a cool way of getting truck IFS with new brakes and all.
Has anyone done this kind of swap? If so can you tell me your story? Would you recommend it?
Zeke
#202600 03/02/2006 12:59 AM
The bottom line is ,It's a lot of careful work.Know what your doing.Do a little more reserch on your project.Nothing ever falls together.Check the web for more infro plus this site grin
dan-pa
#202601 03/02/2006 1:14 AM
Seon!
You did this with that 57 big window cab right?
Can you tell me anything about the work involved?
Thanks Buddy,
Zeke
#202602 03/02/2006 3:25 AM
Hey Zeke, the actual work isn't hard at all ... what makes it easy is having the right tools available, time on hand and dollars to throw at the project :rolleyes: .
My 9K 2 post lift was a big asset in lifting my '56 Burb body off it's stock frame. Only took a couple of hours of measuring, fabricating and welding the body mounts. It would probably would have taken a couple of days without the lift.
Just remember measure twice, cut once.
Pic
Here\'s the donor chassis, '00 GMC with Vortec engine and auto transmssion. BTW the '56 big window in the back ground sits on a '75 GMC dually frame.
Here\'s a shot of one of the body mounts before welding.
And here\'s the Burb resting on the '00 GMC frame.
I don't know if I answered your question :confused: .
#202603 03/02/2006 6:06 AM
Yes, you've answered - can it be done?
The answer is Yes! Cool!
Would you happen to have any photos of the body mounts under the 56/75 combo? That's the kind of rig I'm contemplating. Just a 1/2 ton version with the 454. VROOOOM!!!!
Thanks Seon!
Zeke
PS: I'd love to come and buy that BW cab from you but it's just too far away for me. I'd have to make it into a summer holiday or something.
#202604 03/02/2006 6:24 AM
Sorry no pics. I did the swap before I had a digital camera frown . But did you see the custom frame I put in the classified?
Pic
#202605 03/02/2006 7:37 AM
Very impressive work.
