1 members (Forty9),
96
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,072 Posts1,055,903 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 123 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 123 | I am working on my 1950 3/4 ton p/u. I have re-done the brakes and am installing new lines. The body parts have been removed to be cleaned and primed. My questions are these...do I need to remove the rear cover of the rear end in order to drain it? Is this a smart thing to do???drain out the old fluid?? If I have to remove the cover I might as well take a look inside right? If so what should I be looking for? Is there anything I should check to make sure the rear end is ok or is there anything I should replace???it had 4.57 gears. any ideas would be welcome. Ed | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | should be a drain plug on the bottom, but if you're into it while the frame's clear, take off the cover after draining and you can see if the pot needs a bit of a flush to get rid of slug left in the bottom - only thing to look for is chipped teeth and sloppy bearings [high wear]
Bill | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | There is no drain plug on the 3/4 ton. Best way to drain the oil is to remove one of the bottom cover bolts. It certainly won't hurt to remove the cover and clean the bottom of the housing. Either way, when you put the bolt(s) back in they need some sealant on the threads.
Also check the vent for obstruction. It's on the top of the housing, driver's side. It unscrews, 1/4" pipe thread. Has a sheet metal fitting to keep out the dirt. If it's plugged your gear lube will expand when warm, overpressure and blow out the axle or pinion sealss.
Fred 52 3600 69 C-10
| | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | Put a 9" FORD readend in that sucker.
dan-pa
| | | | | Joined: Jul 2004 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2004 Posts: 78 | To drain the oil from the rearend remove the bottom bolt on rear of the housing (the bumper side). The oil will then drain. And yes sealant on the threads. Steve | | |
