| | | Forums66 Topics128,031 Posts1,055,434 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 33 Junior Member | | Junior Member Joined: Oct 2005 Posts: 33 | can someone inform me on what ohms I need? I have a 6 volt system still and fuel gauge is original.I think it is 0-30ohms. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Volts is volts. It doesn't matter to the sending unit. You are correct that it requires a 30 ohm sending unit. You can get them (a universal) from about any supplier for 30 to 50 dollars. I have one I bought & used on my 38 until I found an original. It works fine but will probably need a longer float wire if your tank stands on edge. Mine laid flat so I had to shorten the wire. You can make one out of a coat hanger. I'd probably let it go for quite a bit less than a new one if you're interested.
