6 members (Gdads51, 52Carl, Otto Skorzeny, dwreills, 55shaker, 32Fordpuchoptop), 70 guests, and 3 robots.
Topics128,036
Posts1,055,460
Members48,422
#202340 03/20/2006 11:48 PM
Junior Member
Junior Member
can someone inform me on what ohms I need? I have a 6 volt system still and fuel gauge is original.I think it is 0-30ohms.
#202341 03/21/2006 2:13 AM
Ex Hall Monitor
Ex Hall Monitor
Volts is volts. It doesn't matter to the sending unit. You are correct that it requires a 30 ohm sending unit. You can get them (a universal) from about any supplier for 30 to 50 dollars. I have one I bought & used on my 38 until I found an original. It works fine but will probably need a longer float wire if your tank stands on edge. Mine laid flat so I had to shorten the wire. You can make one out of a coat hanger. I'd probably let it go for quite a bit less than a new one if you're interested.
