| | | Forums66 Topics128,180 Posts1,057,067 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 42 Junior Member | | Junior Member Joined: Jan 2006 Posts: 42 | I have a re-built V-8 in my '66 GMC no casting numbers that I can find or any I.D. So is there a general reference guide book to approx. :rolleyes: what kind of chevy v-8 I've got :confused: ? As usual any thanks in advance.
jcf
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | there'll be numbers, unless someone went to a lot of bother to grind'em off! look on the sides of the block and on the bellhousing flange at the back, drivers side - you won't figure out what it is otherwise here's some general stuff about 350 family - and here's a place that'll pinpoint casting number locations [scroll down to links, "CHEVY V-8 CASTING NUMBER LOCATIONS" - also a page of the numbers there Bill | | | | | Joined: Jan 2006 Posts: 42 Junior Member | | Junior Member Joined: Jan 2006 Posts: 42 | Great Links(bookmarked). I'll keep you posted on what I found.
jcf
