| | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | my truck is a '58, but I'm pretty sure the engine isn't original. All the numbers I can make out on the passenger side in front of the head are - 0630DB.
Doesn't the DB mean 283 or 307? I hope not, but that's what it looked like to me....
It's an old engine, no screw on oil filter (has the old style case bolted in the center).. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | So what's the matter with a 283? | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | not much wrong with a 283, except i thought it was a 327 and preferred that...
now, it doesn't matter much, just want to know what i have.. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | sounds likely to be a 283, and in a 58 it just might be original - a 327 is just an 'overstressed' 283 and more finiky - the 283 will last longer, and can be built to be as fast as a 327
did you get the numbers off the block behind the head on the drivers side? [on flywheel flange - if it's in the truck use a mirror] 327= [62-64]3782870, 3789817, 3852174 [65-67]3782870, 3789817, 3858174, 3892657 [68-69]3914660, 3914678, 3932386, 3955618
if it's outta the truck the crankshaft flange can indicate pre or post 68, and I think that at least the early 327's still had the filter can, maybe all of them
the number at the back will tell you
Bill | | | | | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | The DB suffix was used for certain 283 car/El Camino engines from '58 thru '67, some with powerglide, some with 3- or 4-speeds. In '68, that suffix was used for a 307 car/El Camino engine. I don't think DB was used after '68.
Curt ---- 1953 Chevy 6400, 1957 Chevy 2dr Sedan --"Mediocrity is easy, the good things take time"
| | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | thanks all... I'll get a mirror and check the back tonight ...tried before I posted but couldn't get my old [censored] bent enough  | | | | | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | I have to revise and clarify what I posted above.
From actual Chevy parts manuals and the "Catalog of Chevy Truck ID Numbers", the DB suffix was used for the '58-'61 passenger car 283 with powerglide and 4 bbl. carb. That suffix doesn't show up again until '65, where it designated a 2 bbl. 283 backed by a 4-speed used in the Chevelle/El Camino. DB continued thru '67 for the Chevelle/Camino 283, and in '68 designated the 2 bbl. 307 used in the Chevelle/Camino.
Regardless, with the DB being used for the 307 for one year only, chances are good it's a 283.
| | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | Originally posted by Xram53: Regardless, with the DB being used for the 307 for one year only, chances are good it's a 283. I'm inclined to agree - plus, it's a 4 barrel. To me, that's good news. 283 is a better deal than a 307 in my opinion.. | | |
