7 members (MickeyP, RoadsScholar, Gdads51, 1955 1 Series, thekid1950, tclederman, klhansen),
117
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,068 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 45 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 45 | Hello, I am looking to put a NAPCO system in my 59 Apache stepside. The gear ratio is 3.9. Can anyone tell me if that will run at highway speeds when matched to a 3 speed with overdrive? My son will be doing much of the mechanical work on this project. Hope I have explained my question so that it is understandable. Thanks, Ken in NY
Ken in NY
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | a 59 w/ the stock 3.9 ratio can run 60-65 w/ no problems considering the NAPCO's all came w/ the 4spd, and the transfer case suits that, I think it's likely you wouldn't be able to switch the setup to the 3spd - might inquire at this NAPCO site Bill | | | | | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | The only other gear ratio available for your current 3.90:1 setup is a 3.38:1 ratio. These gears have been back ordered for quite some time now, but I think the wait is over! I was able to aquire a set from Golden State Truck parts and they said they had just got them in when I called. It's quite pricey though, ~$400 for the gears and ~$200 for the complete install kit. Those were the prices for just one axle and I believe you would have to both axles on a 4x4 truck (Ouch). I think I would just learn to drive slower.  I know what you mean about driving at highway speeds though. I have 54 GMC with a 261, SM420 4-spd, and 3.90:1 rear gears and the engine really revs at 55MPH. That is why I am changing my rear gears this weekend. I want to be able to drive my rig to some out of state shows this summer and I would like to cruise at 65MPH. Good luck with your project. Jim
1954 GMC 1/2-ton Longbed 1971 Pontiac LeMans Sport
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | The old three speed overdrives were 30% overdriven so behind a 3.90 that gives your a final drive ratio of 2.73. Anything in the high 2's makes a good highway cruiser but is near the edge if loaded or in hilly terrain and forget trailer towing in OD.
Evan
| | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | I have 57 Chevy that I installed a Napco setup in. It originally had 3.90 gears, but since one ring & pinion set was chipped, I replaced both axles with 3.38 gears from Patricks (very helpful & he gave me a discount on the seccond set since I ordered both at once). I have a 3spd overdrive trans installed. So far so good, but I really haven't driven it much since I'm re-doing the body. Some people suggest that 3.38 gears with a the 3spd overdrive is way too tall for a rock climbing NAPCO. My logic is that I won't be doing any rock climbing and I don't have to put it in overdrive unless I want to (e.g., highway cruising). In any case, I'll find out how it works, but it seems to me that if you're not worried about extreme off-road conditions the set-up should be reasonable. I have a modified 261 in it now, I've decided to go to a 283 V8 sometime soon, so that may help mitigate the gearing even more. As they say, it's my truck, my time & my money; I'll make it the way I want it. | | |
