| | | Forums66 Topics128,134 Posts1,056,410 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 88 Member | | Member Joined: Nov 2005 Posts: 88 | Is the cab the only body piece on a 47-53 1 1/2 ton that will fit on a 3100? Any help would be greatly appreciated. | | | | | Joined: Mar 2005 Posts: 267 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 267 | belive so hauler i know the front fender wheel opening is larger so as to fit the bigger wheels tom
I don't suffer from insanity, I enjoy every minute of it!
| | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | The hood outta work off a 1.5 ton truck on a 1/2 ton (3100).. the grill bars can be used out of a 1.5 ton grill to fix bent or missing bars in a 1/2 ton grill.. but the big trucks running boards are shorter, and the front fenders have bigger openings than the 1/2 and 3/4 trucks.
| | | | | Joined: Jul 2002 Posts: 102 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 102 | I'm pretty sure the hoods are about 1 1/2" longer on the big trucks. The grills are bigger for sure. I think the cabs and doors are all that will interchange.
Ron Thompson 51 Chevy 1/2 ton 36 F@rd coupe 65 Riviera
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Fumblin is mistaken on the hood. Ron got it right. Fumblin is right on the grille bars. They can be used on the 3100 grille frame for replacements. | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | The hoods, grilles, fenders...they're all bigger. | | | | | Joined: Jul 2002 Posts: 102 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 102 | HighSchool hauler, aren't you glad we cleared that up?
