6 members (TexasJim50, Stovebolt48, 32Fordpuchoptop, lumbersawyer, JW51, 1 invisible), 56 guests, and 0 robots.
Topics128,080
Posts1,055,945
Members48,430
#201713 02/21/2006 12:11 AM
Another question,can you run tubeless tires on orginal 1953 rims. THANKS DON
Mr.Giant
1953 Chevrolet 3100 in the Gallery
1959 GMC 860 Single Axle Truck Tractor in the Gallery
#201714 02/21/2006 12:16 AM
Original 1953 rims with tubeless 215/85/16 radials:
[img]http://www.whizzerick.com/shoptruck.JPG[/img]
1953 Chevrolet 1300 - Daily driver
Collecting Vintage Whizzer motorbikes
#201715 02/21/2006 12:17 AM
Depends on the wheel.
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass.
Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
#201716 02/21/2006 12:27 AM
You will probably need a tube. Not all places will put a tube in a radial, and you will not have a warranty because of the tube. But it can be done.
Fred
52 3600
69 C-10
#201717 02/21/2006 12:39 AM
got 215/85/16R's (sans tubes) on my 53 gmc 1/2 ton 6 lug, 6.50x16 1 piece rims, no problems.
tony
Overland Blue, 1953 GMC 1/2T, 100-22, 228/1bbl, 4sp/4.10 6v, shortbed/fender side/5-window.
#201718 02/21/2006 1:32 AM
have tubeless on my 52... no problem,,
Redryder pix
My Hotrod
#201719 02/21/2006 3:06 AM
I had one wheel a while back that leaked around the rivets but other than that,no problems.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#201720 02/21/2006 3:31 AM
ODSS President
ODSS President
Just turned over 24k on tubeless 215 85r 16's, daily driver, no probs.
~ Cosmo
1949 Chevy Half Ton
#201721 02/21/2006 4:11 AM
Thankd guys,I realy wanted to put radials on ,thanks again. DON
Mr.Giant
